Zum Hauptinhalt wechseln
Dell Latitude E6400 Hard Drive Replacement
Was du brauchst
    • First, turn off your laptop and disconnect any external adapter.
  1. Dell Latitude E6400 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Release the latch or latches connected to the battery that hold it in place.
  2. Dell Latitude E6400 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the old battery from its storage bay.
    • Plug in the external AC adapter to fully charge the new battery.
  3. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive: Schritt 5, Bild 1 von 1
    • After removing the battery, locate and remove the two M3 x 3-mm screws securing the hard drive to the base assembly. Then, slide the hard drive from the base assembly.
  4. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive bezel: Schritt 6, Bild 1 von 1
    • Next, remove the M3 x 3-mm screw on the hard drive bezel and remove the hard drive bezel. NOTE: Be mindful not to touch the components of the drive. Doing so could damage the drive.
Abschluss
With your replacement hard drive, reassemble your device by performing the instructions above in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Aaron Thomas
1.251 Reputation
10 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.991 Anleitungen geschrieben
2 Kommentare zur Anleitung
Easy hard drive replacement!
Jeffrey P - Antwort
Buenas tardes mi dell e6400 al reproducir video o música de escucha con disco rayado y el video se pausa. Me podrían apoyar para su reparación
Arbey Gatica Sambrano - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 39
Insgesamt: 1,839
