Einleitung
Because the latitude E6400 has just one screw to remove to access the upgradable guts, this process takes no more than 5 minutes to do. It's also very easy.
Pictures and text written by ouimetnick.
Was du brauchst
Simultaneously slide the battery latches (outlined by the red box) to the dock connector in the middle.
This will release the battery. Just slide the battery away from the computer.
Open up the computer and press and hold the power button for 5 seconds. This drains any power left inside the computer.
This is important, as if electricity remains in the notebook, it can shock you and damage the logic board.
Loosen the center screw with a philips screw driver. This is the only screw that needs to be loosened.
It can't be removed as it is captive the the bottom plate.
Now slide the plate away from the dock connector.
Locate the RAM slot.
the system can hold 2 RAM modules.
This unit has 1 module. It is a 1GB one.
Push the metal spreaders (shown in the blue rectangle) straight away from the RAM module.
The RAM module should pop up to a 45 degree angle.
Pull the RAM module straight out from the way it was raised. (Once it pops up to a 45 degree angle, pull it straight out from its current position).
Insert the new RAM into the empty slot, ensuring that the notch in the RAM lines up with the slot (see picture).
Slide the bottom plate on.
Slide it to the rear of the notebook. (battery compartment)
tighten the screw.
Do not over-tighten. Doing so will strip the screw.
19 weitere Personen haben diese Anleitung absolviert.
9 Kommentare zur Anleitung
I assume that in Step 4, you install the new memory modules
In my case, I needed to add a second memory board (2nd memory slot). If possible, would be interesting to have this additional step included in the guide.
