Zum Hauptinhalt wechseln
Dell Latitude E6400 RAM Replacement
Was du brauchst
  1. Dell Latitude E6400 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Dell Latitude E6400 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Simultaneously slide the battery latches (outlined by the red box) to the dock connector in the middle.
    • This will release the battery. Just slide the battery away from the computer.
    • Open up the computer and press and hold the power button for 5 seconds. This drains any power left inside the computer.
    • This is important, as if electricity remains in the notebook, it can shock you and damage the logic board.
  2. Dell Latitude E6400 RAM Replacement: Schritt 2, Bild 1 von 2 Dell Latitude E6400 RAM Replacement: Schritt 2, Bild 2 von 2
    • Loosen the center screw with a philips screw driver. This is the only screw that needs to be loosened.
    • It can't be removed as it is captive the the bottom plate.
    • Now slide the plate away from the dock connector.
  3. Dell Latitude E6400 RAM Replacement: Schritt 3, Bild 1 von 2 Dell Latitude E6400 RAM Replacement: Schritt 3, Bild 2 von 2
    • Locate the RAM slot.
    • the system can hold 2 RAM modules.
    • This unit has 1 module. It is a 1GB one.
    • Push the metal spreaders (shown in the blue rectangle) straight away from the RAM module.
    • The RAM module should pop up to a 45 degree angle.
  4. Dell Latitude E6400 RAM Replacement: Schritt 4, Bild 1 von 1
    • Pull the RAM module straight out from the way it was raised. (Once it pops up to a 45 degree angle, pull it straight out from its current position).
    • Insert the new RAM into the empty slot, ensuring that the notch in the RAM lines up with the slot (see picture).
  5. Dell Latitude E6400 RAM Replacement: Schritt 5, Bild 1 von 2 Dell Latitude E6400 RAM Replacement: Schritt 5, Bild 2 von 2
    • Slide the bottom plate on.
    • Slide it to the rear of the notebook. (battery compartment)
    • tighten the screw.
    • Do not over-tighten. Doing so will strip the screw.
  6. Dell Latitude E6400 RAM Replacement: Schritt 6, Bild 1 von 2 Dell Latitude E6400 RAM Replacement: Schritt 6, Bild 2 von 2
    • Slide the battery in until it clicks.
    • Press the power button.
    • AND it works.
Abschluss
19 weitere Personen haben diese Anleitung absolviert.
Nicholas Ouimet
3.655 Reputation
11 Anleitungen geschrieben
9 Kommentare zur Anleitung
I assume that in Step 4, you install the new memory modules
Peter Bourke - Antwort Teilen
When/how to fit the new memory modules is unclear. I have a blue flashing A light and can't start up. Looking for solutions.
Linda - Antwort Teilen
It would be helpful to add a link to troubleshooting info here
Instead of "assuming" why not READ all of Step 4; especially the second paragraph, which states: "Insert the new RAM into the empty slot, ensuring that the notch in the RAM lines up with the slot (see picture)."
Nadaword - Antwort Teilen
In my case, I needed to add a second memory board (2nd memory slot). If possible, would be interesting to have this additional step included in the guide.
Pedro Pontes - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 55
Insgesamt: 50,830
