Zum Hauptinhalt wechseln
Dell Latitude E6420 Keyboard Replacement
Was du brauchst
  1. Dell Latitude E6420 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Latitude E6420 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: Schritt 3, Bild 1 von 2 Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: Schritt 3, Bild 2 von 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Latitude E6420 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Keyboard Replacement, Backplate: Schritt 5, Bild 1 von 2 Dell Latitude E6420 Keyboard Replacement, Backplate: Schritt 5, Bild 2 von 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Latitude E6420 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Keyboard Replacement, Keyboard: Schritt 7, Bild 1 von 3 Dell Latitude E6420 Keyboard Replacement, Keyboard: Schritt 7, Bild 2 von 3 Dell Latitude E6420 Keyboard Replacement, Keyboard: Schritt 7, Bild 3 von 3
    • Use the plastic opening tool to remove the bezel from around the keyboard.
  8. Dell Latitude E6420 Keyboard Replacement: Schritt 8, Bild 1 von 2 Dell Latitude E6420 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Using the screwdriver, remove four 3mm Phillips #0 screws from the keyboard.
  9. Dell Latitude E6420 Keyboard Replacement: Schritt 9, Bild 1 von 2 Dell Latitude E6420 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Lift the keyboard and use the spudger to disconnect the keyboard cable.
    • Gently lift the keyboard to prevent damage to the cable.
  10. Dell Latitude E6420 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Lift the keyboard out of the laptop.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Madysen Eames
1.555 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 33
Insgesamt: 3,482
