Zum Hauptinhalt wechseln
Dell Latitude E6420 Screen Replacement
Was du brauchst
  1. Dell Latitude E6420 Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Latitude E6420 Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Screen Replacement: Schritt 2, Bild 1 von 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Screen Replacement, Screen: Schritt 3, Bild 1 von 2 Dell Latitude E6420 Screen Replacement, Screen: Schritt 3, Bild 2 von 2
    • Open the laptop and lay it flat on your work surface.
    • Using the spudger, lift the bezel up from around the laptop screen.
  4. Dell Latitude E6420 Screen Replacement: Schritt 4, Bild 1 von 3 Dell Latitude E6420 Screen Replacement: Schritt 4, Bild 2 von 3 Dell Latitude E6420 Screen Replacement: Schritt 4, Bild 3 von 3
    • Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
    • Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
    • Lift the screen.
  5. Dell Latitude E6420 Screen Replacement: Schritt 5, Bild 1 von 1
    • Lift the laptop screen and flip it over to lay it on top of the keyboard.
  6. Dell Latitude E6420 Screen Replacement: Schritt 6, Bild 1 von 2 Dell Latitude E6420 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the piece of tape from the back of the LCD cable.
  7. Dell Latitude E6420 Screen Replacement: Schritt 7, Bild 1 von 2 Dell Latitude E6420 Screen Replacement: Schritt 7, Bild 2 von 2
    • Lift the piece of tape attached to the LCD cable.
    • Once the tape has lifted, gently pull back to unplug the LCD cable.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Madysen Eames
1.555 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 Mitglieder
Ein Kommentar
Bonjour, Merci
endibos - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 21
Letzte 30 Tage: 28
Insgesamt: 4,187
