Zum Hauptinhalt wechseln
Dell Latitude E6510 Heat Sink Replacement
Was du brauchst
  1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: Schritt 1, Bild 1 von 3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: Schritt 1, Bild 2 von 3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: Schritt 1, Bild 3 von 3
    • Locate the tabs that lock the battery in place.
    • Push tabs towards each other while simultaneously pushing the battery away from the device.
  2. Dell Latitude E6510  Heat Sink Replacement: Schritt 2, Bild 1 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 2, Bild 2 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
    • Slide the panel back until it unlocks.
  3. Dell Latitude E6510  Heat Sink Replacement: Schritt 3, Bild 1 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 3, Bild 2 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 3, Bild 3 von 3
    • Locate the fan plug.
    • Pull up until it is unplugged from the reciever.
    • Take caution when unplugging the fan plug from the receiver.
  4. Dell Latitude E6510  Heat Sink Replacement: Schritt 4, Bild 1 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 4, Bild 2 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the two 5.5 mm screws securing the fan.
    • Lift the end of the fan opposite the copper wire up.
    • Pull the fan away from the device.
  5. Dell Latitude E6510  Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • Locate and loosen the four silver screws holding down the heat redistribute component.
    • Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
  6. Dell Latitude E6510  Heat Sink Replacement: Schritt 6, Bild 1 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 6, Bild 2 von 3 Dell Latitude E6510  Heat Sink Replacement: Schritt 6, Bild 3 von 3
    • Lift the metal plate up on the end closest to the screws.
    • Slide the whole assembly away from where you removed the fan.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 22
Letzte 30 Tage: 28
Insgesamt: 1,030
