Zum Hauptinhalt wechseln
Dell Latitude E6510 USB Ports Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-3 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Dell Latitude E6510  USB Ports Replacement, Fan: Schritt 1, Bild 1 von 2 Dell Latitude E6510  USB Ports Replacement, Fan: Schritt 1, Bild 2 von 2
    • Slide the two black clips toward the middle to release battery
  2. Dell Latitude E6510  USB Ports Replacement: Schritt 2, Bild 1 von 2 Dell Latitude E6510  USB Ports Replacement: Schritt 2, Bild 2 von 2
    • Remove the back plate from the back of the device
    • Remove the 6 screws with the J1 screwdriver.
    • once the screws are out, slide back panel towards front of the device and lift up
  3. Dell Latitude E6510  USB Ports Replacement: Schritt 3, Bild 1 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 3, Bild 2 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 3, Bild 3 von 3
    • Remove two screws holding the fan
    • Slide from under copper heat sink
    • Unplug connector and remove
    • To reassemble, follow directions in reverse
  4. Dell Latitude E6510  USB Ports Replacement, USB Ports: Schritt 4, Bild 1 von 2 Dell Latitude E6510  USB Ports Replacement, USB Ports: Schritt 4, Bild 2 von 2
    • Remove the battery
    • Flip the computer so that it is facing downward.
    • Next locate the two black clips as shown in the image.
    • Slide the clips toward the middle in order to release the battery.
  5. Dell Latitude E6510  USB Ports Replacement: Schritt 5, Bild 1 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 5, Bild 2 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 5, Bild 3 von 3
    • Remove the back plate from the back of the device.
    • Using the Philips head screwdriver remove the 6 screws marked in red.
    • Next, slide the panel down and then lift up til completely removed.
  6. Dell Latitude E6510  USB Ports Replacement: Schritt 6, Bild 1 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 6, Bild 2 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 6, Bild 3 von 3
    • Press the button on the side of the optical drive in order to release the pull tab.
    • Next, pull out the optical drive located on the lower left hand side.
    • Locate the hard drive on the lower right hand side and remove it from the computer.
  7. Dell Latitude E6510  USB Ports Replacement: Schritt 7, Bild 1 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 7, Bild 2 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 7, Bild 3 von 3
    • Using the Philips head screwdriver unscrew the two screws holding the fan.
    • Next, slide the fan out from under the copper heat sink.
    • Unplug the connector marked in blue and remove the fan.
  8. Dell Latitude E6510  USB Ports Replacement: Schritt 8, Bild 1 von 2 Dell Latitude E6510  USB Ports Replacement: Schritt 8, Bild 2 von 2
    • Using the Philips head screwdriver unscrew the seven screws holding down the copper heat sink.
    • Lift the heat sink slightly and slide out to remove it.
  9. Dell Latitude E6510  USB Ports Replacement: Schritt 9, Bild 1 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 9, Bild 2 von 3 Dell Latitude E6510  USB Ports Replacement: Schritt 9, Bild 3 von 3
    • Using a spudger remove the volume bar above the keyboard
    • Using the Philips head screwdriver unscrew the two screws near the top of the keyboard.
    • Lift the keyboard membrane slightly by tab, and slide the keyboard towards the screen in order to remove.
    • Using the Philips head screwdriver unscrew the three screws marked in green.
  10. Dell Latitude E6510  USB Ports Replacement: Schritt 10, Bild 1 von 1
    • Using the Philip head screwdriver unscrew the eight screws holding down the chassis to get to the USB ports.
  11. Dell Latitude E6510  USB Ports Replacement: Schritt 11, Bild 1 von 1
    • Remove the USB port by using a soldering iron to take out the connections on either side of the port.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 19
Insgesamt: 1,449
