Zum Hauptinhalt wechseln
Dell Latitude E6510 Speaker Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-3 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Dell Latitude E6510 Speaker Replacement, Keyboard: Schritt 1, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement, Keyboard: Schritt 1, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Open the laptop and locate the volume panel on the keyboard.
    • Use the spudger to get underneath the righthand side of the panel and gently pry up the side.
  2. Dell Latitude E6510 Speaker Replacement: Schritt 2, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 2, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the detached volume panel from the keyboard.
    • Locate the two screws holding the keyboard in place. Then Remove these screws with a Philips PH1 head screwdriver.
  3. Dell Latitude E6510 Speaker Replacement: Schritt 3, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 3, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Locate the tab near the back of the keyboard.
    • Pull upwards on the tab to start removing the keyboard and then using both hands at the sides, pull until the keyboard comes free.
  4. Achtung: Die Schritte 4-6 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Dell Latitude E6510 Speaker Replacement, Battery: Schritt 4, Bild 1 von 1
    • Make sure the device is shutdown
    • Position the laptop upside down with the battery facing towards you.
    • Locate the battery latches circled in red.
  5. Dell Latitude E6510 Speaker Replacement: Schritt 5, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Gently slide both latches inward until you hear both latches release.
  6. Dell Latitude E6510 Speaker Replacement: Schritt 6, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 6, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Pull the battery towards yourself as shown until completely removed from the computer.
  7. Achtung: Die Schritte 7-11 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Dell Latitude E6510 Speaker Replacement, Fan: Schritt 7, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement, Fan: Schritt 7, Bild 2 von 2
    • Flip over laptop and locate door panel screws.
    • Remove the Screws.
  8. Dell Latitude E6510 Speaker Replacement: Schritt 8, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 8, Bild 2 von 2
    • Slide and remove the access door.
  9. Dell Latitude E6510 Speaker Replacement: Schritt 9, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 9, Bild 2 von 2
    • Locate the fan and two fan screws.
    • Remove the 2 screws using a PZ0 Phillip head screwdriver.
  10. Dell Latitude E6510 Speaker Replacement: Schritt 10, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 10, Bild 2 von 2
    • Using a plastic spudger, gently pry the fan upwards.
    • Once the fan has been loosened, slowly remove the main fan component.
    • Do not pull too hard as their is still a wire attached.
  11. Dell Latitude E6510 Speaker Replacement: Schritt 11, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 11, Bild 2 von 2
    • Locate the wire holding the fan in place and detach the clip.
  12. Dell Latitude E6510 Speaker Replacement, Speaker: Schritt 12, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement, Speaker: Schritt 12, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement, Speaker: Schritt 12, Bild 3 von 3
    • Remove the hard drive.
    • Pull the drive right and out of the computer.
  13. Dell Latitude E6510 Speaker Replacement: Schritt 13, Bild 1 von 1
    • Remove the small battery.
    • Undo the blue circle first.
    • Pull out the end of the cord by the plastic part to avoid damage to the wire.
  14. Dell Latitude E6510 Speaker Replacement: Schritt 14, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 14, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 14, Bild 3 von 3
    • Loosen but do not remove the silver screws surrounding the heat sink using a PZ1 screwhead.
  15. Dell Latitude E6510 Speaker Replacement: Schritt 15, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 15, Bild 2 von 2
    • Remove the heat sink from the laptop.
  16. Dell Latitude E6510 Speaker Replacement: Schritt 16, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 16, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 16, Bild 3 von 3
    • Push the silver clips on both sides of the memory cards outwards.
    • Gently pull the cards out one at a time.
  17. Dell Latitude E6510 Speaker Replacement: Schritt 17, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 17, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 17, Bild 3 von 3
    • Unscrew the side panels on both sides and slide them off.
  18. Dell Latitude E6510 Speaker Replacement: Schritt 18, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 18, Bild 2 von 2
    • Remove the screws of the back framework.
  19. Dell Latitude E6510 Speaker Replacement: Schritt 19, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 19, Bild 2 von 2
    • Loosen the two highlighted screws, do not remove.
  20. Dell Latitude E6510 Speaker Replacement: Schritt 20, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 20, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 20, Bild 3 von 3
    • Undo the cables until the are not attached to the back half of the keyboard.
    • Pull the cables backwards and to the side of the laptop.
  21. Dell Latitude E6510 Speaker Replacement: Schritt 21, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 21, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 21, Bild 3 von 3
    • Undo the other side also.
    • The cables should only be loose, not removed.
  22. Dell Latitude E6510 Speaker Replacement: Schritt 22, Bild 1 von 2 Dell Latitude E6510 Speaker Replacement: Schritt 22, Bild 2 von 2
    • Partially open the laptop.
    • Side the top half of the laptop backwards towards yourself to undo it from the bottom half.
  23. Dell Latitude E6510 Speaker Replacement: Schritt 23, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 23, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 23, Bild 3 von 3
    • Pry the frame work of the laptop off using a plastic splunger.
    • Proceed slowly, any screws that may have been missed can break your laptop if not removed.
  24. Dell Latitude E6510 Speaker Replacement: Schritt 24, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 24, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 24, Bild 3 von 3
    • Remove the screws from the wireless detector.
    • Remove the detector.
  25. Dell Latitude E6510 Speaker Replacement: Schritt 25, Bild 1 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 25, Bild 2 von 3 Dell Latitude E6510 Speaker Replacement: Schritt 25, Bild 3 von 3
    • Remove the screws from the top and bottom of both speakers.
    • Remove the speakers.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 2,744
