Einleitung
The WLAN Adapter Card is what allows the computer to connect to Wi-Fi.
The WLAN Adapter Card is connected to the laptop by 2 J0 PH screws with a head size of 4.44 mm and a length of 3.67 mm.
Was du brauchst
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Gently pull the two wires connected to the WLAN Adapter Card.
Remove the two electrode connectors.
Remove the single 3.67 mm JIS #0 screw that holds the WLAN Adapter Card to the laptop.
Eine weitere Person hat diese Anleitung absolviert.
