Zum Hauptinhalt wechseln
Einleitung
The WLAN Adapter Card is what allows the computer to connect to Wi-Fi.
The WLAN Adapter Card is connected to the laptop by 2 J0 PH screws with a head size of 4.44 mm and a length of 3.67 mm.
Ersatzteile
Keine Ersatzteile angegeben.
  1. With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop. When the latches are unlocked, a small logo resembling an open padlock will become visible.
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Grasp the battery from the top and pull upward. Grasp the battery from the top and pull upward.
    • Grasp the battery from the top and pull upward.
  3. Remove the ten 8.6 mm JIS #0 screws. Remove the ten 8.6 mm JIS #0 screws.
    • Remove the ten 8.6 mm JIS #0 screws.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Place fingers underneath cover and pull off the cover.
    • Place fingers underneath cover and pull off the cover.
  6. Gently pull the two wires connected to the WLAN Adapter Card.
    • Gently pull the two wires connected to the WLAN Adapter Card.
  7. Remove the two electrode connectors. Remove the single 3.67 mm JIS #0 screw that holds the WLAN Adapter Card to the laptop.
    • Remove the two electrode connectors.
    • Remove the single 3.67 mm JIS #0 screw that holds the WLAN Adapter Card to the laptop.
    • The WLAN Adapter Card will pop up once the screws are taken out.
  8. Pull WLAN Adapter Card to remove it from the laptop. Pull WLAN Adapter Card to remove it from the laptop.
    • Pull WLAN Adapter Card to remove it from the laptop.
Abschluss
Alec Weiss
752 Reputation
8 Anleitungen geschrieben
IUPUI, Team S2-G2, Baechle Fall 2018 Mitglied von IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 80
