Zum Hauptinhalt wechseln
Dell Latitude E6530 Battery Replacement
  1. Dell Latitude E6530 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the computer over so that the bottom panel is facing you.
  2. Dell Latitude E6530 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Latitude E6530 Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide the switches away from each other to release the battery.
  3. Dell Latitude E6530 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Latitude E6530 Battery Replacement: Schritt 3, Bild 2 von 2
    • Using your hands, gently remove the battery from the device.
Abschluss
To reassemble your device, follow these instructions in reverse order. If issues arise after replacing the battery, refer to the troubleshooting page or additional links for more help.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 728
