Einleitung
This guide will walk users through replacing the Dell Latitude E6530 fan. Refer to the troubleshooting guide before beginning fan replacement to determine and clarify the problem.
Was du brauchst
Begin by flipping the computer over to the bottom.
Using a spudger, insert it into the corner of the back panel and move it around the panel.
Remove the back panel completely.
Unhook the cord connecting the fan to the computer.
Carefully pull the fan out of the computer.
To reassemble your device, follow these instructions in reverse order. Refer to the troubleshooting guide and additional links if problem persists.
