Zum Hauptinhalt wechseln
Dell Latitude E6540 Thermal paste Replacement
Was du brauchst
  1. Dell Latitude E6540 Thermal paste Replacement, Thermal paste: Schritt 1, Bild 1 von 2 Dell Latitude E6540 Thermal paste Replacement, Thermal paste: Schritt 1, Bild 2 von 2
    • First remove the 3 screws to remove the lead
  2. Dell Latitude E6540 Thermal paste Replacement: Schritt 2, Bild 1 von 1
    • Then remove those 7 screws in order and try to keep track of which each screw place for when you assemble it back
  3. Dell Latitude E6540 Thermal paste Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the fan connector
  4. Dell Latitude E6540 Thermal paste Replacement: Schritt 4, Bild 1 von 1
    • carefully shake the heatsink until the thermal past loosens and it moves freely
  5. Dell Latitude E6540 Thermal paste Replacement: Schritt 5, Bild 1 von 1
    • Now pull down the heat sink from its place
  6. Dell Latitude E6540 Thermal paste Replacement: Schritt 6, Bild 1 von 1
    • Clean off the old thermal paste from the heat sink, CPU, and GPU, and then apply the new thermal paste
  7. Dell Latitude E6540 Thermal paste Replacement: Schritt 7, Bild 1 von 1
    • put everything back into place, and don't forget to attack the connector to its place, and with that you are done
Abschluss
Hunter
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 58
