Zum Hauptinhalt wechseln
Dell Latitude E7250 RAM Replacement
Was du brauchst
  1. Dell Latitude E7250 RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Latitude E7250 RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: Schritt 2, Bild 1 von 3 Dell Latitude E7250 RAM Replacement, RAM: Schritt 2, Bild 2 von 3 Dell Latitude E7250 RAM Replacement, RAM: Schritt 2, Bild 3 von 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: Schritt 3, Bild 1 von 3 Dell Latitude E7250 RAM Replacement: Schritt 3, Bild 2 von 3 Dell Latitude E7250 RAM Replacement: Schritt 3, Bild 3 von 3
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 54
Insgesamt: 4,778
