Zum Hauptinhalt wechseln
Dell Latitude E7250 SSD Replacement
Was du brauchst
  1. Dell Latitude E7250 SSD Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Latitude E7250 SSD Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 SSD Replacement, SSD: Schritt 2, Bild 1 von 3 Dell Latitude E7250 SSD Replacement, SSD: Schritt 2, Bild 2 von 3 Dell Latitude E7250 SSD Replacement, SSD: Schritt 2, Bild 3 von 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 SSD Replacement: Schritt 3, Bild 1 von 3 Dell Latitude E7250 SSD Replacement: Schritt 3, Bild 2 von 3 Dell Latitude E7250 SSD Replacement: Schritt 3, Bild 3 von 3
    • Locate your SSD, it is on the right side and held in with a small screw.
    • Unscrew the SSD carefully. Once done, the SSD will "pop" upwards at an angle making removal easy.
    • Gently grasp the SSD on either side with your thumb and forefinger and pull away from the computer.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Thanks a lot for this !
viperx007 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 37
Letzte 30 Tage: 145
Insgesamt: 10,832
