Zum Hauptinhalt wechseln
Dell Latitude E7270 Battery Replacement
Was du brauchst
  1. Dell Latitude E7270 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Battery Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
On Step 4 there is no screw on middle since that hole is for backpanel center screw.
Mikko Kuusio - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 72
Insgesamt: 3,475
