Zum Hauptinhalt wechseln
Dell Latitude E7270 Solid State Drive Replacement
Was du brauchst
  1. Dell Latitude E7270 Solid State Drive Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Solid State Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Solid State Drive Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Solid State Drive Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Solid State Drive Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Solid State Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Solid State Drive Replacement, Solid State Drive: Schritt 7, Bild 1 von 1
    • Locate the SSD stick on the bottom right of the device.
    • In absence of an SSD, it was substituted with a RAM stick for visual/educational purposes only. The SSD in your device will look similar to your RAM and may vary in color.
  8. Dell Latitude E7270 Solid State Drive Replacement: Schritt 8, Bild 1 von 1
    • Use your fingers and pull the SSD towards you to remove it from it's socket.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 56
Insgesamt: 4,048
