Zum Hauptinhalt wechseln
Dell Latitude E7440 Battery Replacement
Was du brauchst
  1. Dell Latitude E7440 Battery Replacement, Prepare the laptop: Schritt 1, Bild 1 von 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Battery Replacement, Release the battery: Schritt 2, Bild 1 von 3 Dell Latitude E7440 Battery Replacement, Release the battery: Schritt 2, Bild 2 von 3 Dell Latitude E7440 Battery Replacement, Release the battery: Schritt 2, Bild 3 von 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Battery Replacement, Remove the battery: Schritt 3, Bild 1 von 1
    • Lift the battery by the top, away from the laptop body.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Akash Kedia
1.445 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G5, White Winter 2019 Mitglied von Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Mitglieder
2 Kommentare
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Anwar Ben Tanfous - Antwort
Any recommended site to buy original battery?
Razin Ahmed - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 40
Letzte 30 Tage: 76
Insgesamt: 5,818
