Zum Hauptinhalt wechseln
Dell Latitude E7440 CMOS Battery Replacement
Was du brauchst
  1. Dell Latitude E7440 CMOS Battery Replacement, Prepare the laptop: Schritt 1, Bild 1 von 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: Schritt 2, Bild 1 von 3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: Schritt 2, Bild 2 von 3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: Schritt 2, Bild 3 von 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 CMOS Battery Replacement, Remove the battery: Schritt 3, Bild 1 von 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: Schritt 4, Bild 1 von 2 Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: Schritt 4, Bild 2 von 2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 CMOS Battery Replacement: Schritt 5, Bild 1 von 2 Dell Latitude E7440 CMOS Battery Replacement: Schritt 5, Bild 2 von 2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 CMOS Battery Replacement: Schritt 6, Bild 1 von 3 Dell Latitude E7440 CMOS Battery Replacement: Schritt 6, Bild 2 von 3 Dell Latitude E7440 CMOS Battery Replacement: Schritt 6, Bild 3 von 3
    • Position your nylon spudger on the edge of the white connector, in between the connector and the port.
    • Pull back on the connector until the plastic head disconnects from the port on the laptop body.
    • If the connector is stuck, move the broader end of the spudger back and forth across the connector to slowly loosen the connection.
  7. Dell Latitude E7440 CMOS Battery Replacement: Schritt 7, Bild 1 von 1
    • Separate the wrapped battery stack from the body by pulling up the wire.
    • You may need to use the flat end of the nylon spudger to separate the battery.
    • The stack is attached using glue, so you might hear a pop when removing it.
    • Reapplying an adhesive to the bottom of the battery is recommended, although not necessary, to keep it in place.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Akash Kedia
1.445 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G5, White Winter 2019 Mitglied von Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Mitglieder
2 Kommentare
You list no part number for the replacement battery. Do we know the part number? I looked on Dell's website and find nothing. Otherwise, nice write-up!
jess13j - Antwort
@jess13j, battery is a CR2032 coin cell.
senzog - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 29
Letzte 30 Tage: 104
Insgesamt: 14,177
