Zum Hauptinhalt wechseln
Dell Latitude E7440 Hard Drive Replacement
Was du brauchst
  1. Dell Latitude E7440 Hard Drive Replacement, Prepare the laptop: Schritt 1, Bild 1 von 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Replacement, Release the battery: Schritt 2, Bild 1 von 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: Schritt 2, Bild 2 von 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: Schritt 2, Bild 3 von 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Replacement, Remove the battery: Schritt 3, Bild 1 von 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
    • Slide the service tray using the middle stand offs to then be able to lift the tray off.
  5. Dell Latitude E7440 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Latitude E7440 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove four M2 x 3mm Phillips #0 screws from the hard drive cage.
    • Remove the hard drive cage by lifting it off the laptop.
    • The hard drive cage is not pictured here, but the screws will be in these locations.
  6. Dell Latitude E7440 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Dell Latitude E7440 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the hard drive connector from the top of the drive.
    • iFixit's device came without a hard drive to picture. Your device will have a component connected to the thin, black connector.
    • The hard drive connector can be removed from the laptop body to make replacement easier.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S2-G5, White Winter 2019 Mitglied von Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Mitglieder
5 Anleitungen geschrieben
3 Kommentare zur Anleitung
Hi, my problem is the opposite, I have an hard drive but seems like my HDD connector doesn't plug in the small port. I can send you a pic, I need help
†Winterfall† - Antwort Teilen
I want to use a Seagate hard disk, but when I start it, it demands me a password. Can you help me in this case please?
Aldoni JB - Antwort Teilen
It sounds like your BIOS is locked to only work with that hard drive
Magnus Vacuum - Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 43
Letzte 30 Tage: 145
Insgesamt: 13,623
