Zum Hauptinhalt wechseln
Dell Latitude E7440 Trackpad Replacement
Was du brauchst
  1. Dell Latitude E7440 Trackpad Replacement, Trackpad: Schritt 1, Bild 1 von 2 Dell Latitude E7440 Trackpad Replacement, Trackpad: Schritt 1, Bild 2 von 2
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Trackpad Replacement: Schritt 2, Bild 1 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 2, Bild 2 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide access door down and remove it by slightly jerking it. Make sure no part of the door is sticking to the components.
  3. Dell Latitude E7440 Trackpad Replacement: Schritt 3, Bild 1 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 3, Bild 2 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 3, Bild 3 von 3
    • Remove two 5mm screws using the Phillips #0 screwdriver.
    • Unplug highlighted cable. Be careful not to snap it in half.
  4. Dell Latitude E7440 Trackpad Replacement: Schritt 4, Bild 1 von 1
    • Remove the fan from the device.
  5. Dell Latitude E7440 Trackpad Replacement: Schritt 5, Bild 1 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 5, Bild 2 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Remove cables on the bottom.
  6. Dell Latitude E7440 Trackpad Replacement: Schritt 6, Bild 1 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 6, Bild 2 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 6, Bild 3 von 3
    • Remove the following screws using the Phillips #0 screwdriver.
    • Five 5mm screws.
    • Seven 3mm screws.
    • One 8mm screw.
  7. Dell Latitude E7440 Trackpad Replacement: Schritt 7, Bild 1 von 1
    • Remove the keyboard bezel. This might take some effort. Use some force in one direction only.
  8. Dell Latitude E7440 Trackpad Replacement: Schritt 8, Bild 1 von 2 Dell Latitude E7440 Trackpad Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 2.5mm mouse button screws using the Phillips #0 screwdriver.
    • Remove the mouse button.
  9. Dell Latitude E7440 Trackpad Replacement: Schritt 9, Bild 1 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 9, Bild 2 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 9, Bild 3 von 3
    • Remove three 3mm screws using the Phillips #0 screwdriver.
    • Remove the keyboard by pulling it in one direction.
  10. Dell Latitude E7440 Trackpad Replacement: Schritt 10, Bild 1 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 10, Bild 2 von 3 Dell Latitude E7440 Trackpad Replacement: Schritt 10, Bild 3 von 3
    • Disconnect the cables from the device.
    • Remove a single 5mm screw using the Phillips #0 screwdriver.
    • Remove the trackpad panel.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team S1-G1, Stella Fall 2019 Mitglied von IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 3,011
