Einleitung
This guide introduces how to remove the battery from Dell Latitude E7470. The laptop comes with different battery configurations. While this guide shows how to replace a standard capacity battery, the procedure is similar when replacing the extended capacity battery.
Was du brauchst
Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
10 weitere Personen haben diese Anleitung absolviert.
