Zum Hauptinhalt wechseln
Dell Latitude E7470 Network Card Replacement
Was du brauchst
  1. Dell Latitude E7470 Network Card Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Network Card Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Network Card Replacement: Schritt 3, Bild 1 von 2 Dell Latitude E7470 Network Card Replacement: Schritt 3, Bild 2 von 2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Network Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Network Card Replacement, Network Card: Schritt 5, Bild 1 von 2 Dell Latitude E7470 Network Card Replacement, Network Card: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Halberd Spudger
    $2.99
    Kaufen
    • Use a halberd spudger and your fingers to detach two wires from the Wi-Fi card.
  6. Dell Latitude E7470 Network Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
  7. Dell Latitude E7470 Network Card Replacement: Schritt 7, Bild 1 von 1
    • Use an iFixit opening tool and your fingers to pull the Wi-Fi card out of its socket.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 673
