Zum Hauptinhalt wechseln
Dell Latitude ST Battery Replacement
Was du brauchst
  1. Dell Latitude ST Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Latitude ST Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Latitude ST Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Battery Replacement: Schritt 2, Bild 1 von 3 Dell Latitude ST Battery Replacement: Schritt 2, Bild 2 von 3 Dell Latitude ST Battery Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Battery Replacement: Schritt 3, Bild 1 von 3 Dell Latitude ST Battery Replacement: Schritt 3, Bild 2 von 3 Dell Latitude ST Battery Replacement: Schritt 3, Bild 3 von 3
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Battery Replacement: Schritt 4, Bild 1 von 3 Dell Latitude ST Battery Replacement: Schritt 4, Bild 2 von 3 Dell Latitude ST Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Battery Replacement: Schritt 5, Bild 1 von 3 Dell Latitude ST Battery Replacement: Schritt 5, Bild 2 von 3 Dell Latitude ST Battery Replacement: Schritt 5, Bild 3 von 3
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Battery Replacement: Schritt 6, Bild 1 von 3 Dell Latitude ST Battery Replacement: Schritt 6, Bild 2 von 3 Dell Latitude ST Battery Replacement: Schritt 6, Bild 3 von 3
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Where can I get the battery for it
Brandon Allen - Antwort
Where do I find a new battery for it at
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 946
