Zum Hauptinhalt wechseln
Dell Latitude ST Camera Replacement
Was du brauchst
  1. Dell Latitude ST Camera Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Latitude ST Camera Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Latitude ST Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Camera Replacement: Schritt 2, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 2, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Camera Replacement: Schritt 3, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 3, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 3, Bild 3 von 3
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Camera Replacement: Schritt 4, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 4, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 4, Bild 3 von 3
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Camera Replacement: Schritt 5, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 5, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 5, Bild 3 von 3
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Camera Replacement: Schritt 6, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 6, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 6, Bild 3 von 3
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
  7. Dell Latitude ST Camera Replacement, Screen: Schritt 7, Bild 1 von 3 Dell Latitude ST Camera Replacement, Screen: Schritt 7, Bild 2 von 3 Dell Latitude ST Camera Replacement, Screen: Schritt 7, Bild 3 von 3
    • Pull up on the copper antenna tape to loosen it from the base.
    • Unscrew the seven 6mm Phillips #0 screws from the base.
  8. Dell Latitude ST Camera Replacement: Schritt 8, Bild 1 von 2 Dell Latitude ST Camera Replacement: Schritt 8, Bild 2 von 2
    • Locate the grey LCD cable attached to the motherboad on the device.
    • Pull up on the black tape handle attached to the LCD cable to disconnect the cable.
    • Be sure to pull on the back rather than the LCD cable itself.
  9. Dell Latitude ST Camera Replacement: Schritt 9, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 9, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 9, Bild 3 von 3
    • Using your hands or the blue plastic opening tool, go along the edges of the frame and unsnap the screen from the middle frame.
    • Lift the middle frame away from the screen.
  10. Dell Latitude ST Camera Replacement, Camera: Schritt 10, Bild 1 von 2 Dell Latitude ST Camera Replacement, Camera: Schritt 10, Bild 2 von 2
    • Unplug the white camera cord located on the right side of the middle frame under the WLAN card.
    • Using your hands, or the blue plastic opening tool, pull the white part of the cable to the right to disconnect it.
  11. Dell Latitude ST Camera Replacement: Schritt 11, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 11, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 11, Bild 3 von 3
    • Flip over the middle frame.
    • Locate the black and red cables attached to the camera assembly.
    • Gripping them by the white tag, disconnect the black and red cables from their socket on the camera assembly.
  12. Dell Latitude ST Camera Replacement: Schritt 12, Bild 1 von 3 Dell Latitude ST Camera Replacement: Schritt 12, Bild 2 von 3 Dell Latitude ST Camera Replacement: Schritt 12, Bild 3 von 3
    • Remove the 6mm Phillips #0 screw next to the camera.
    • Pull the camera out to remove it from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 292
