Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Replacing a Latch on the Dell Latiude X300
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure the power is off.
    • Make sure the power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Remove rubber caps on each corner of the front screen with a pinch. Remove the 4 mm screws located on the front screen of the laptop.
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Carefully, remove the screen casing using either your hands or a proper tool.
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so use extreme care.
  4. Remove the screws holding the latch in place.
    • Remove the screws holding the latch in place.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Jacob
9 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 Mitglied von UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G1
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 208
