Was du brauchst
Turn the laptop over so that the bottom is facing up.
Remove the two #0 3 mm screws holding the cover plate.
Push both metal retaining clips outward at the same time using your hands carefully.
Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
Fast fertig!
To reassemble your device, reinstall cover plate with two #0 screws.
Abschluss
