Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Turn the laptop over so that the bottom is facing up. Remove the two #0 3 mm screws holding the cover plate.
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Push both metal retaining clips outward at the same time using your hands carefully.
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Gently pull the memory out of the retainer at the same 45 degree angle.
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  4. Insert the new memory at 45 degree angle.
    • Insert the new memory at 45 degree angle.
  5. Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
Abschluss
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
23 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-20, Maness Winter 2012 Mitglied von Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 2,088
