Zum Hauptinhalt wechseln
Dell OptiPlex FX170 Memory Board Replacement
Was du brauchst
  1. Dell OptiPlex FX170 Memory Board Replacement, Case: Schritt 1, Bild 1 von 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 Memory Board Replacement: Schritt 2, Bild 1 von 2 Dell OptiPlex FX170 Memory Board Replacement: Schritt 2, Bild 2 von 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 Memory Board Replacement: Schritt 3, Bild 1 von 3 Dell OptiPlex FX170 Memory Board Replacement: Schritt 3, Bild 2 von 3 Dell OptiPlex FX170 Memory Board Replacement: Schritt 3, Bild 3 von 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 Memory Board Replacement: Schritt 4, Bild 1 von 2 Dell OptiPlex FX170 Memory Board Replacement: Schritt 4, Bild 2 von 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 Memory Board Replacement, Memory Board: Schritt 5, Bild 1 von 1
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 1,417
