Zum Hauptinhalt wechseln
Dell OptiPlex FX170 RAM Replacement
Was du brauchst
  1. Dell OptiPlex FX170 RAM  Replacement, Case: Schritt 1, Bild 1 von 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 RAM  Replacement: Schritt 2, Bild 1 von 2 Dell OptiPlex FX170 RAM  Replacement: Schritt 2, Bild 2 von 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 RAM  Replacement: Schritt 3, Bild 1 von 3 Dell OptiPlex FX170 RAM  Replacement: Schritt 3, Bild 2 von 3 Dell OptiPlex FX170 RAM  Replacement: Schritt 3, Bild 3 von 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 RAM  Replacement: Schritt 4, Bild 1 von 2 Dell OptiPlex FX170 RAM  Replacement: Schritt 4, Bild 2 von 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 RAM  Replacement, RAM: Schritt 5, Bild 1 von 2 Dell OptiPlex FX170 RAM  Replacement, RAM: Schritt 5, Bild 2 von 2
    • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
  6. Dell OptiPlex FX170 RAM  Replacement: Schritt 6, Bild 1 von 1
    • Lift and pull out the RAM.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,337
