Zum Hauptinhalt wechseln
Dell OptiPlex GX260 Optical Drive Replacement
Was du brauchst
  1. Dell OptiPlex GX260 Optical Drive Replacement, Case: Schritt 1, Bild 1 von 2 Dell OptiPlex GX260 Optical Drive Replacement, Case: Schritt 1, Bild 2 von 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: Schritt 2, Bild 1 von 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: Schritt 2, Bild 2 von 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: Schritt 2, Bild 3 von 3
    • Identify the optical drive in the case.
    • Remove the analog audio cable from the optical drive.
    • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
    • Remove the power cable from the optical drive.
  3. Dell OptiPlex GX260 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Push the two green tabs toward each other to release the optical drive and lift it out.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 4-48, Amido Fall 2010 Mitglied von Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 8,950
