Was du brauchst
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
Once the fan is released, lift it straight up and out of the case.
Disconnect the ATX power cable to the motherboard.
Disconnect the P4 12V(4x2) power cable from the motherboard.
Disconnect the front panel ribbon cable by gently pulling it straight up.
Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard.
Disconnect the optical drive audio cable connector from the motherboard.
Disconnect the audio input/output cable from the motherboard.
Lift the metal tab near the right corner of the motherboard.
Pull the green tab toward the front of the PC to release the motherboard.
From the rear of the PC, push the ports in while lifting the motherboard up and flipping it away from you.
Stand the motherboard up as shown.
Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
Remove the screw at the rear of the motherboard.
Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base.
With the motherboard out of the tray, let your soldering gear warm up and get a desoldering braid.
Desoldering can damage motherboards, so first practice on a board you don't need. Use a 40-50W soldering iron with a chisel tip and 0.080" wide desoldering braid. Also helpful are rosin flux and 60/40 tin/lead solder, in case all the solder doesn't come out. Wiggle desoldered leads to verify they're free, and never pull on any that aren't.
Install the new capacitor in the holes left by the old one, then solder it into place.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
