Einleitung
One may require the use of this guide when the audio jack on the front of their Dell Optiplex 745 Small Form Factor or their USB's do not function properly. The purpose of having an audio jack and USB ports on the front of your desktop is primarily for headphones and temporary devices you would use with your desktop, such as: uploading pictures from a camera, transferring files to a USB drive, uploading music onto an Ipod or MP3 player, and so on.
Before starting this guide it may be useful to troubleshoot your audio jack and USB ports to make sure it is the desktop's hardware that is the issue or that your drivers are up to date instead since the 745 is an older model. Here is a link to a helpful webpage on windows 10 driver installation in case that is the issue: https://answers.microsoft.com/en-us/wind...
  1. Pull the tab and the lid will pop up. Pull the tab and the lid will pop up.
    • Pull the tab and the lid will pop up.
  2. Grab the lid and pull it up and off. Grab the lid and pull it up and off.
    • Grab the lid and pull it up and off.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • When creating this guide a cable was absent, in the picture you will find where that cable would be connected.
  5. Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
    • Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
  6. Carefully grasp the audio panel  from the sides, pull it back and out of it's slot. Carefully grasp the audio panel  from the sides, pull it back and out of it's slot.
    • Carefully grasp the audio panel from the sides, pull it back and out of it's slot.
Abschluss
Jeremy Nicholas
201 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S5-G5, Walkup Fall 2017 Mitglied von USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 263
