Einleitung
In this guide, we will show you how to take out the CPU (processor), and replace it with a new one.
Was du brauchst
The processor is located inside the heat sink (indicated by the marker).
Unscrew the 9.5 mm screws from heatsink on both sides using the Phillips #2 screwdriver.
Push the small lever downwards, then sideways and upwards, in order to release it from the hook.
Remove the processor from its casing.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
