Zum Hauptinhalt wechseln
Dell Optiplex GX620 CPU Replacement
Was du brauchst
  1. Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: Schritt 1, Bild 1 von 2 Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: Schritt 1, Bild 2 von 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CPU Replacement: Schritt 2, Bild 1 von 2 Dell Optiplex GX620 CPU Replacement: Schritt 2, Bild 2 von 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CPU Replacement, Dell Optiplex GX620 Side Panel Disassembly: Schritt 3, Bild 1 von 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: Schritt 4, Bild 1 von 3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: Schritt 4, Bild 2 von 3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: Schritt 4, Bild 3 von 3
    • Move the cables out of your way.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: Schritt 5, Bild 1 von 3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: Schritt 5, Bild 2 von 3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: Schritt 5, Bild 3 von 3
    • Unplug the power cable
    • Unplug the data cable
  6. Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: Schritt 6, Bild 1 von 2 Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: Schritt 6, Bild 2 von 2
    • Unplug the fan that is on the motherboard.
  7. Dell Optiplex GX620 CPU Replacement: Schritt 7, Bild 1 von 2 Dell Optiplex GX620 CPU Replacement: Schritt 7, Bild 2 von 2
    • There is two Phillips #2 screws that need to be removed.
    • The two screws have springs that keep them there.
  8. Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: Schritt 8, Bild 1 von 3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: Schritt 8, Bild 2 von 3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: Schritt 8, Bild 3 von 3
    • Lift the heat sink.
  9. Dell Optiplex GX620 CPU Replacement, CPU removal.: Schritt 9, Bild 1 von 3 Dell Optiplex GX620 CPU Replacement, CPU removal.: Schritt 9, Bild 2 von 3 Dell Optiplex GX620 CPU Replacement, CPU removal.: Schritt 9, Bild 3 von 3
    • Push and release tap on it. And then take the CPU out.
    • Remember to put new thermal paste on the CPU.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Padraic Hoselton
4.312 Reputation
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 2,460
