Zum Hauptinhalt wechseln
Dell Optiplex GX620 Hard Drive
Was du brauchst
  1. Dell Optiplex GX620 Hard Drive, How to unplug and discharge before repair: Schritt 1, Bild 1 von 2 Dell Optiplex GX620 Hard Drive, How to unplug and discharge before repair: Schritt 1, Bild 2 von 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Hard Drive: Schritt 2, Bild 1 von 2 Dell Optiplex GX620 Hard Drive: Schritt 2, Bild 2 von 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Hard Drive, Dell Optiplex GX620 Side Panel Disassembly: Schritt 3, Bild 1 von 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: Schritt 4, Bild 1 von 3 Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: Schritt 4, Bild 2 von 3 Dell Optiplex GX620 Hard Drive, Disconnect hard drive.: Schritt 4, Bild 3 von 3
    • Remove the power and SATA data cables.
    • SATA power
    • SATA data
  5. Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: Schritt 5, Bild 1 von 3 Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: Schritt 5, Bild 2 von 3 Dell Optiplex GX620 Hard Drive, Take hard drive out of the slot.: Schritt 5, Bild 3 von 3
    • Pull the two tabs on the hard drive and pull up
  6. Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: Schritt 6, Bild 1 von 3 Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: Schritt 6, Bild 2 von 3 Dell Optiplex GX620 Hard Drive, Remove hard drive from slot enclosure.: Schritt 6, Bild 3 von 3
    • Now take the tray off of the hard drive.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Padraic Hoselton
4.282 Reputation
12 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
327 Mitglieder
1.682 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 2,423
