Zum Hauptinhalt wechseln
Dell Optiplex SX280 Battery Replacement
Was du brauchst
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: Schritt 1, Bild 1 von 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Optiplex SX280 Battery Replacement: Schritt 2, Bild 2 von 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Optiplex SX280 Battery Replacement: Schritt 3, Bild 2 von 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Dell Optiplex SX280 Battery Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: Schritt 5, Bild 1 von 2 Dell Optiplex SX280 Battery Replacement: Schritt 5, Bild 2 von 2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: Schritt 6, Bild 1 von 1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: Schritt 7, Bild 1 von 2 Dell Optiplex SX280 Battery Replacement: Schritt 7, Bild 2 von 2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: Schritt 8, Bild 1 von 1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: Schritt 9, Bild 1 von 1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: Schritt 10, Bild 1 von 3 Dell Optiplex SX280 Battery Replacement: Schritt 10, Bild 2 von 3 Dell Optiplex SX280 Battery Replacement: Schritt 10, Bild 3 von 3
    • Upon replacement, simply push the battery into the motherboard.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Tom
841 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 22-4, Maness Fall 2010 Mitglied von Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Mitglieder
26 Anleitungen geschrieben
Ein Kommentar
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 11,767
