Einleitung
Replace the Heat Sink on the Motherboard to maintain optimal performance
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  5. Remove the large blue cover from the computer, there are no screws or tabs keeping it in place. Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  6. Press down on the release tab above the heat sink. Press down on the release tab above the heat sink.
    • Press down on the release tab above the heat sink.
  7. Pull the heat sink out of the computer while pressing on the release tab. When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Tom
799 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 22-4, Maness Fall 2010 Mitglied von Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Mitglieder
13 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 5,673
