Zum Hauptinhalt wechseln
Dell Optiplex SX280 Lower Fan Replacement
Was du brauchst
  1. Dell Optiplex SX280 Lower Fan Replacement, Panel Cover: Schritt 1, Bild 1 von 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Lower Fan Replacement: Schritt 2, Bild 1 von 2 Dell Optiplex SX280 Lower Fan Replacement: Schritt 2, Bild 2 von 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Lower Fan Replacement: Schritt 3, Bild 1 von 2 Dell Optiplex SX280 Lower Fan Replacement: Schritt 3, Bild 2 von 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: Schritt 4, Bild 1 von 2 Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: Schritt 4, Bild 2 von 2
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Lower Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the power supply by pressing the release tab. It is distinguished by the black, red, green, and yellow wires.
  6. Dell Optiplex SX280 Lower Fan Replacement: Schritt 6, Bild 1 von 2 Dell Optiplex SX280 Lower Fan Replacement: Schritt 6, Bild 2 von 2
    • Remove the rubber grommets from the base of the fan. The iFixit Opening tool may be useful in this step.
  7. Dell Optiplex SX280 Lower Fan Replacement: Schritt 7, Bild 1 von 2 Dell Optiplex SX280 Lower Fan Replacement: Schritt 7, Bild 2 von 2
    • Press on the blue release tab and remove the fan.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Tom
841 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 22-4, Maness Fall 2010 Mitglied von Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Mitglieder
26 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 4,200
