Einleitung
This guide is designed to help replace a broken fan from the tower. When working with anything electrical make sure to disconnect it from the power source.
Was du brauchst
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
Remove the power supply by pressing the release tab. It is distinguished by the black, red, green, and yellow wires.
Remove the rubber grommets from the base of the fan. The iFixit Opening tool may be useful in this step.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
