Einleitung
Remove the Motherboard from the computer.
Was du brauchst
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
The RAM are the two green cards in the corner of the computer.
At each end of the card, there are two white clips securing the RAM to the Motherboard.
Push down both white clips with your thumbs until you hear a click.
The RAM cards can now be removed.
Unplug the blue cable that connects the hard drive to the motherboard.
Squeeze the release tabs on either side of the hard drive.
Then slide the hard drive out of the computer while squeezing the tabs.
Press on the release tab and remove the motherboard speaker which is attached to the side of the tower.
Unplug the cable that powers the hard drive, which has orange, red and yellow wires.
Unplug the cable that powers the emergency shut off, distinguished by its red wires.
Slide the Hard Drive Stand to left side.
Remove the stand from the rest of the rear panel.
Remove the four screws located on heat sink stand.
The heat sink stand can now be lifted from the motherboard.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Good job. Thanks for sharing, friend.
Great guide! I got stuck at the Mobo tray, I knew the black screws were involved but couldn't get it with out help. Thanks!
Fans can be removed with board tray, otherwise they're getting pulled off their rubber isolating feet. Once out with the mobo, the fans slide off the board tray with their plastic shoes attached.
