Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Rotate the photo printer so that the bottom of the case faces upward.
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Remove the back panel of the case by pulling directly back.
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Finally remove the side panel with the ink-cartridge door by holding the right side  and pulling backwards with the left side. Caution! The side panel is held in by tabs; don't break these.
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
Abschluss
Jonathan Mintz
11 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 14-7, Forte Spring 2012 Mitglied von Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 555
