Zum Hauptinhalt wechseln
Einleitung
This guide is a preliminary guide to accessing the control panel motherboard. This motherboard controls the control keys of the printer.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Rotate the photo printer so that the bottom of the case faces upward.
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Remove the back panel of the case by pulling directly back.
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Finally remove the side panel with the ink-cartridge door by holding the right side  and pulling backwards with the left side. Caution! The side panel is held in by tabs; don't break these.
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
  7. Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
    • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
  8. Locate the red and black cable that is connecting the fan to the top of the logic board.
    • Locate the red and black cable that is connecting the fan to the top of the logic board.
  9. Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
    • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
  10. Locate the data ribbon that connects the LCD panel to the mother board. Loosen the fasteners next to the ribbon by carefully pushing them away from the white ribbon holder. Once the fasteners are loosened the ribbon should easily slide away from the motherboard.
    • Locate the data ribbon that connects the LCD panel to the mother board.
    • Loosen the fasteners next to the ribbon by carefully pushing them away from the white ribbon holder.
    • Once the fasteners are loosened the ribbon should easily slide away from the motherboard.
  11. Locate the clips with multi-colored wires that connect the motherboard to the printing unit. Disconnect both of them by gently pulling them away from the motherboard. Disconnect both of them by gently pulling them away from the motherboard.
    • Locate the clips with multi-colored wires that connect the motherboard to the printing unit.
    • Disconnect both of them by gently pulling them away from the motherboard.
  12. Locate the white ribbon that connects the motherboard to the printing feed. Disconnect the ribbon by gently pulling the ribbon away from the motherboard. Disconnect the ribbon by gently pulling the ribbon away from the motherboard.
    • Locate the white ribbon that connects the motherboard to the printing feed.
    • Disconnect the ribbon by gently pulling the ribbon away from the motherboard.
  13. The mother board has changed orientation. Notice the new orientation based on the white data ribbon we removed in the previous step. Locate the black data ribbon that connects the mother board to the printing motors.
    • The mother board has changed orientation. Notice the new orientation based on the white data ribbon we removed in the previous step.
    • Locate the black data ribbon that connects the mother board to the printing motors.
    • Disconnect it from the logic board, by gently pulling the wire away from the mother board.
  14. Now unscrew the three screws 7.89mm (counter-clockwise) using a Phillips #1 screwdriver.
    • Now unscrew the three screws 7.89mm (counter-clockwise) using a Phillips #1 screwdriver.
  15. Once screws and ribbons are disconnected, you can pull mother board away from the printing unit.
    • Once screws and ribbons are disconnected, you can pull mother board away from the printing unit.
  16. Gain access to the bottom of the top case with a thin horizontal control panel motherboard attached to the bottom.
    • Gain access to the bottom of the top case with a thin horizontal control panel motherboard attached to the bottom.
    • Remove the front panel.
    • The dell top casing should now only have two sides.
  17. Locate the four 7.85 mm screws attaching the control panel motherboard to the top face casing. Use a Phillips Head #1 screw driver to remove the four highlighted screws.
    • Locate the four 7.85 mm screws attaching the control panel motherboard to the top face casing.
    • Use a Phillips Head #1 screw driver to remove the four highlighted screws.
    • NOTE: Make sure removal of front face plate is completed.
  18. Gently lift the horizontal control panel motherboard and square power switch board.
    • Gently lift the horizontal control panel motherboard and square power switch board.
    • Completely detach the motherboard from the face casing.
    • NOTE: Leave the power switch control attached to the main control panel motherboard.
Abschluss
Kishan Patel
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-7, Forte Spring 2012 Mitglied von Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 574
