Was du brauchst
Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
Pry the edges of the base cover and lift it to remove it from the computer.
Disconnect the battery cable from the system board [1].
Remove the seven M2x4 screws that secure the battery to the computer [2].
Lift the battery off the computer [3].
Remove the four M2x4 screws securing the hard-drive bracket to the computer [1].
Lift the hard-drive cage [2] off the hard drive assembly [3].
Disconnect the hard-drive cable from the system board [1].
Lift the hard drive off the palm rest assembly [2].
Disconnect the hard drive interposer from the hard drive assembly and then remove the hard drive covers away from the hard drive.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
