Einleitung
The guide shows how to remove the keyboard from a Dell Precision 7560. The keyboard is a core component of the computer, so keeping on top of its maintenance is vital. If the issue with the keyboard isn't merely debris keeping a key from functioning, then this guide will assist you in replacing the keyboard entirely.
Was du brauchst
Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
Remove the back cover by lifting at the corners.
Unscrew and remove the five 2 mm screws that secure the battery.
Locate the battery connector.
Pull the connector towards you to disconnect it.
Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
Pulling from the tab, carefully remove the connector.
Turn the device over and open the screen to expose the keyboard.
Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
Carefully remove the keyboard from the device.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Guide is close, but not completely correct. Just need a little more attention to detail.
