Zum Hauptinhalt wechseln
Dell Precision 7560 Keyboard Replacement
Was du brauchst
  1. Dell Precision 7560 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Precision 7560 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Precision 7560 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: Schritt 2, Bild 1 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 2, Bild 2 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: Schritt 3, Bild 1 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 3, Bild 2 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Precision 7560 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Precision 7560 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: Schritt 5, Bild 1 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 5, Bild 2 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: Schritt 6, Bild 1 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 6, Bild 2 von 3 Dell Precision 7560 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jack Allred
336 Reputation
2 Anleitungen geschrieben
Utah Tech University, Team 1-1, McMurrin Spring 2023 Mitglied von Utah Tech University, Team 1-1, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G1
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 738
