Einleitung
The motherboard of a computer is its control center and can seem daunting to replace. This guide will demonstrate how to efficiently replace the motherboard for a Dell Precision 7560 laptop.
Motherboards can be damaged by rough handling, drops, water damage, or power surges.
Some possible indications of a failing motherboard are: external USB devices are no longer being read by the laptop correctly, if at all; the laptop is operating much slower than normal; the computer boots with a blank blue screen, and/or any burning smell coming from the laptop while operating.
Power off and unplug your device before beginning.
Was du brauchst
Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
Remove the back cover by lifting at the corners.
Unscrew and remove the five 2 mm screws that secure the battery.
Locate the battery connector.
Pull the connector towards you to disconnect it.
Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
Unscrew and remove the two 3 mm screws that secure the solid-state drive.
Remove the top cover of the Solid State Drive by lifting up from the corners.
Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
With an appropriate replacement part, exchange the old SSD with a new one.
Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
Lift to remove the metal overlay.
Disconnect the wires attached to the Wi-Fi card.
Lift from the sides to remove the Wi-Fi card.
Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
Remove, carefully and completely, any wires running over the frame.
Grab securely and lift to remove the metal frame.
Flip up the metal edge holding down the SD connection.
Gently pull to disconnect the connecting strip.
Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
Holding the sides, lift to remove the metal cap.
Lift to disconnect the wire bundle.
Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
Flip the motherboard over, exposing the underside.
Pull to disconnect the wires leading to the speaker unit.
