Einleitung
This guide shows how to replace NVMe expansion sticks on a Dell Precision 7560 laptop. You will need to pull gently.
Was du brauchst
Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
Remove the back cover by lifting at the corners.
Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
Disconnect the left SSD stick by pulling its exposed end towards you.
Repeat the same procedure to the right SSD stick.
