Einleitung
This guide provides step-by-step instructions for replacing the screen on your Dell Precision 7560 laptop, along with tips and precautions to ensure a successful replacement.
Was du brauchst
Using an opener tool, pry open the bezel, following along the screen's perimeter.
Lightly pull from the corners to remove the bezel.
Use the Phillips #0 screwdriver to remove:
Two 2 mm screws from the top screen brackets.
Two 3 mm screws from the bottom screen brackets.
Once these screws are removed, you should be able to gently pry the laptop screen free.
To fully disconnect the screen, gently peel off the white tape that secures the video connector.
Remove the blue tape that lies between the white tape and the video connector.
Open the video connector's bracket and remove the cable, pulling towards the back of the device.
