Zum Hauptinhalt wechseln
Dell Precision 7560 Screen Replacement
Was du brauchst
  1. Dell Precision 7560 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Dell Precision 7560 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Dell Precision 7560 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: Schritt 2, Bild 1 von 2 Dell Precision 7560 Screen Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: Schritt 3, Bild 1 von 3 Dell Precision 7560 Screen Replacement: Schritt 3, Bild 2 von 3 Dell Precision 7560 Screen Replacement: Schritt 3, Bild 3 von 3
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Abschluss
Laisha
202 Reputation
2 Anleitungen geschrieben
Utah Tech University, Team 1-1, McMurrin Spring 2023 Mitglied von Utah Tech University, Team 1-1, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 63
Insgesamt: 638
